Battery dead after speaker install.
JDG2000
Hey y’all, little problem popped up after my speaker install yesterday. I upgraded to some kicker 6.5 inch speakers in the front. They were plug and play from crutch field. 300 watt max and 100 watt RMS. Install went fine, fairly simple, this morning I go to start my car and it’s completely dead. No sound when I go to crank it over. I did not diss connect the batter before I pulled the speaker holder but I feel like that shouldn’t matter since it’s just a plug connection.
What’s happening here? Do I need more power?
Edit: I’m a dummy, pretty sure I accidentally left on a map light...
Yeah, changing speakers shouldn’t have affected anything. I don’t disconnect the battery when I change speakers. If the head unit only turns on when the ignition is on, the head unit shouldn’t be an issue either (?).
Hopefully you didnt short anything out. Or If u played music while off itll drain the battery really quick. Also if u didnt hook up the remote wire correct the amp will stay on and drain the battery.
