Battery Question
adkinsadam1
So the last couple weeks when I've started the truck, often times it would click several times and not start at first, and when it would start the back window wiper would flip once. Then today, the battery I believe is completely dead. No electric anything works. Are all these issues connected to the dying battery? That's what I assumed. Or are they separate issues? Thanks a bunch!
Also, EGG SMELL. The last few days the smell of eggs pouring out of that engine has been unbelievable! What is the cause of that?
time i had egg smell come from my engine bay on my rav4..twas the battery going south...the body of the battery was hotter than normal too........battery died soon after
Sulfur smell could be the battery off-gassing as sulfuric acid is used in lead-acid batteries. The rear wiper thing is one of those odd mysteries that has never been explained by Toyota ; I don't know if some engineer designed it that way, or if the module is just more sensitive to low voltage than others, but its been a fairly reliable indicator of a failing battery.
Druss, Those Panasonic batteries are pretty cool; the majority of them seem to have been an AGM design, so I assume any good AGM brand battery should be fairly comparable.
Uh ha....will keep this new found info of Absorbent Glass Mat (AGM) batteries in mind when looking for a replacement.
Thanks BlackWorksInc!
