bed in runner....
uzibear
meant this as a reply to another thread, but this is fine. i want to put a bed in a 4runner, 1st gen seems best, but can 2nd gen's rear seats be removed?? is the floor raised on 2nd gen?
personally i'd intend to remove the rear seat. is it easily removable?
and what i want to do is relatively simple but i think useful: build a platform above the wheel well like you mentioned. i'd have 2x4 supports in three rows, along the sides and one in the middle. ideally i'd not want to have to attach these supports to the bed of the truck; perhaps the assembly could be lifted in and out with the top off? with big long heavy screws, i shouldn't get too much wiggle room from the struts.
then here's my thought of how to utilize the space underneath: rather than just shoving things under there, i'd like to build two pull-out drawers on wheels. they'd be next to each other (seperated by the row of supports down the middle), on wheels ideally, and pull out so i could get into them, then just shove back in. something like that.
anyway, i wonder if others have done it. i like the 4runner better than trucks because there is no wall between cab and bed. i'm 6ft and i would have to buy a fullsize truck which i don't want. this way i can sleep with my head at the tailgate and even if my toes stick off a bit hopefully it would be ok.
i'd probably just get a 3-5" memory foam mattress "topper" to use as a mattress. most economical might even be to buy a thinner one in king size, and cut it once in half, double it up. not too bad if you have enough padding. tight for two but mostly it would be just me, and my wife is small if she comes :)
with a small truck i'd have to leave the tailgate open, and that's lousy on cold days, and don't want fullsize. i found the 1st gen runner simply because i was looking for something to fit a bed. nice thing about this too is that it's inconspicuous. don't know how much of a dirtbag you are (i'm a climber as well), but i'm fond of avoiding campsite fees and just dossing in a parking lot if in can find it. done it before much in joshua tree. it's a heck of a lot less conspicuous if you don't have a westfalia with your top popped up :)
just make sure not to sleep on the top floor of the MGM grand parking structure in vegas. i tried that once in my 94 explorer and had a rude awakening by security :)
thats one of the great things about the first-gen, in my 88 when i was camping i didnt trust my friends not to draw on me or throw stuff at me while sleeping so i folded the rear seats up, put down an air matress and went to bed in my truck all locked up. im about 6' or 6'1" or so and i could stretch out completely
I don't know if this will help, but, in '84 the back seat was an option. Most 4runners were ordered with the seat, but mine wasn't. Instead, it has a metal plate where the seat should be, making the rear into a flat pickup truck-like bed. If you could find one of these plates, you could just pull all of your gear out of the back and put it on the front seats (and behind the seats) when you're ready to sleep.
team haymaker said:
thats awsome, did you make that yourself?
and im assuming you have a dog because of the cage
Yep I design and make everything myself as thats part of the challenge.
No dog :D . They are called cargo barriers and widely used in many 4WD's and wagons in Oz. Object is if you have to stop suddenly or hit something you won't also get smacked on the back of the head by your gas bottle etc :D .
But also having a front "wall" in the rear section means a lot more camping items etc can be stacked in that section.
But I made mine so I can also access the rear from inside.
JD
thats cool, i was just wondering about the dog because when i used to detail vehicles a few years ago everyone seemed to have dog hair EVERYWHERE and the barriers so the dog wouldnt jump up front
and yes making it is the best part
