Being cheap with the lift.. Need some help.
Maybe tax, tire disposal, tire mounting/balancing?
Did you get the $2k quote in writing or did the guy just say "$2k"?
I got the bill in front of me. Tires $800. Labor $300. The lift kit here is $600. $90 for alignment. $80 to mount and balance. Then $100 for tax.
Kinda high for mount/balance and alig. i just got quoted $60 for m/b, and $60 for alig....do the lift urself, its easy
u got tools? garage? jack? use the search engine on here, there are a TON of lift threads. I did mine. Wasn't the toytech, so i didnt have to take the front struts apart like you will. If you want a cheap way, go with the DS kit. I paid $135 shipped from amazon. Its not a spring kit so it wont improve off roading other then more ground clearance. But it will sustain factory ride which the spring kits do not.
oh, and i WANT your rims, sell them to me cheap :)
pic of mine with the DS 2.5/1.5 kit...........
IMG00356-20110306-1806.jpg~original
Check out the link in my sig, I have several write ups listed there that'll help you out on the install. If you have basic skills and tools you can do the install yourself and order the lift online which will save you a ton.
You should do it yourself and save some money.
Look at the Cornfed 3/2 lift kit. It won't ever sag like the Daystar.
Does anyone have pics of a compressed Daystar spacer? Or, measurements of how much lift you lost? I'm asking because I'm about to buy one of their kits for my 4Runner. I've used their kits on 2 Jeeps without any loss of lift. This one saw a lot of off-road action on a spacer lift.
2001 Jeep Wrangler
The Jeeps had coils all the way around so maybe not as much stress as struts? They're probably lighter too. DS has a lifetime guarentee, but I don't feel like swithing them out if they compress.
2001 Jeep Wrangler
I did quite a bit of searching before I put mine on and never saw any threads about sagging
Well apparently if I do this thing myself I'll save $800. Now the last question I have is what lift should I get? Should I get a 3 all the way around or stick with this: ToyTec - 3" Coil Spring Lift Package - 4Runner and FJ Cruiser
Thanks a lot for all of the opinions.
Jack
What are you planing on doing? If you plan on off roading a lot go with new springs and shocks. If you only plan on off roading occasionally, go with a spacer lift. As said before it will keep the stock ride. Spacer lifts are A LOT cheaper so why spend the money if your not going to use the set up?
no matter what you get, the lift itself is fairly simple. some basic tools, half a day and lava soap is about all you need. i have done 5 here at my house and they are all pretty simple with a few hicups along the way but nothing that cannot be thought through and completed.
save yourself the money and do it yourself. you'll have the pride of looking and saying, "i did that myself"
Theoretically those poly spacers can compress but I've never seen it be a big issue. Hard to beat Daystar for the price. Theres a cornfed 3/2 for sell in the classifieds section.
My .02 is if you really like your truck, then just go lifted with Bilstein 5100 shocks front and rear and toytec rcc2.0 coils (total $550). You resuse your factory front coils. And if you ever want to off road you are well equiped, not just for looks with the spacers.
Bilstein Height adjustable front and matching 5100 Rear shoc - Toytec Lifts: Toyota Lift Kits: FJ Cruiser Lift Kits, Tacoma Lift Kits, Tundra Lift Kits, 4 Runner Lift Kits, Sequoia Lift Kits, Toyota Truck Lift Kits
:iagree: If youve got 550 to spend I would go that route as well. Im happy with my DS i just couldnt afford anything more at the time
My Cornfed lift uses aluminum front spacers. I have never personally seen a Daystar lift sagging, but if you search the net there seems to be quite a bit written about it. The aluminum spacers can not sag, so for about $50 more I think it is worth it.
