Belt diagram for 2002 4runner?
dat5574
Can someone help with a drive belt diagram for a 2002 4runner 3.4 V6?
I want to adjust the tension on the belts due to a chirpping sound to see if that fixes it. Specificially, I think it's the one closest to the ground. I'm guessing I'd have to take off the skid plate to get to it easier from below.
Attached is a photo I found from another post. From my research this engine would be the 5VZ-FE shown. However I'm trying to figure out the rest....
WP – Water Pump
AL – Alternator
IP – Idler pulley
VP – ?
CC – ?
CK – Crankshaft?
Also, which component above adjusts the tension on each belt?
Just starting to do as much as I can myself...thanks for any help. Dave.
WP – Water Pump
AL – Alternator
IP – Idler pulley
VP – ?
CC – ?
CK – Crankshaft?
Yes
CK = Crankshaft
CC = is A/C Compressor
and VP = P/S pump. Toyota calls it a "V"ane "P"ump?
The Alt has its own adjuster.
The P/S has and idler pulley you can adjust and the so does the A/C compressor.
I included a few pictures for reference of the adjusters..
tobasko556
