Best. Deal. Ever.XenonDepot and Baja Designs
Agreed, I can’t believe I waited this long to upgrade my lighting.
The BD fogs are very impressive and install was pretty straight forward [emoji1360]
0ea540d111114908e55c6e2b57f4d6be.heic
e2db45d66bbffbf1db69773cac82d2bd.heic
Dialing in the HIDs a little more this morning...
9501d857d5b98d9dad6207356ed9230a.heic
Is there a way to adjust them horizontally?
The vertical adjustment is done via the BD bracket. Horizontal adjustment would have to be via the oe mounting screws...? Worse case longer screws and a bushing/washers could do the trick?
is the lower spot the fogs? if so doesn't seem like a lot of dispersal for the lower part of the combo lense
Most likely because I'm only about 3' from the garage door. The fogs throw a good amount of light. You can definitely tell when they are on/off.
What's the word on legality of adding HID/LED bulbs to the stock headlamps, especially without a projector retrofit?
No aftermarket LED or HID upgrade kit is DOT approved so they're not road legal. The same goes for a projector retrofit -- it's not considered to be street legal either. If you're concerned about glare (the stock housings do allow some light bleed), then suggest you look at going with an H11 LED kit (not as bright as HID).
Link to review:
https://www.xenondepot.com/2018-4runner-LED-Headlight-s/108.htm
Danny
Just put my LED bulbs and Squadron Sports in to day. I think I should aim my head lights down, but I’m having my lift installed Saturday, so I’ll wait till then. I got the amber combo fogs and I need to try and aim them down a bit, but I think I might order the wide cornering lens and try them too.
Sweet, once you're all set be sure to post some pictures :) Did you make sure that your diodes are facing 3 and 9 o'clock? It makes a big difference as seen in the review I posted above.
Danny
