swooopeno
I call upon the forum. . . again:
So if anyone recalls, I'm installing external DVD and LCD screen. Couldn't install screen in small compartment near shifter, so I am putting it in the glove box w/ rail glides. Anyway, I need some advice on where to tap into power. I need a battery tap, accessory tap, and ground. I took the dash apart last night, and located the needed wires that come off the main stereo plug. Can I use these? Do I need to somehow add another fuse for these items and run the wires to the fuse block near the driver's side door? As discussed in the FM mod. thread, there is an accessory wire (brown/white) near the shifter. Can I use this for accessory wire?
Any help will be VERY appreciated!
Also... can anyone recommend a place to purchase blitzsafe from?
