Best Toyota Shop in Phoenix, AZ?
K-D-Runner
Finally getting around to buying the Doug Thorley Shortie Headers, Magnaflow High Flow Cats, and CEL's from Jason of Burtman Industries.
Was hoping some other AZ runners could point me to a good Toyota shop or even just an exhaust shop you've had good experiences with in order to have everything installed.
The runner's registration is up at the end of this month, and I'm quite confident it won't pass with the headers in their current state. Plus Im just excited for the increase in power and gas mileage, and I've been driven crazy by the ticking.
Thanks in advance!
Sent from my Pixel 3 XL using Tapatalk
Go give Chris a call at Scottsdale Muffler & Automotive. They put on m DT headers and exhaust. Great work and fair pricing.
I have e-mailed Lopers Performance in Phoenix. I was Told they can do the Headers and Y-pipe No Problem. I will give them a Call about Price. I am going DT Long Tube, and DT Y-pipe. Then maybe Dirty Deeds Cat Back. So No Cutting or Welding. I will report back on there Estimate.
I thought it wasn't possible to pass emissions here with the long tubes?
Available at your local automotive store. Spark Plug Non Fouler PN 42009 ($4.99)
You now need to drill out 1 of the non foulers using a 1/2" drill bit. When finished this is what it will look like.
Side by Side comparison of the original and now modified non foulers
O2 Sensor inserted in the modified non fouler
Second, unmodified non fouler now installed on modified non fouler
Original non fouler->Modified non fouler->O2 sensor
Fully installed one of my other vehicles, but I did the exact same with my DT setup.
You can use one longer non-fouler which is what I did after the first time I did this, just make sure it is the same diameter for the O2 sensor. Whatever route you go make sure you have a setup for both sides of the exhaust. They also have these on Ebay and other vendors, however they are usually $15+ for the same thing. Up to how much work you want to put in, if drilling is too much.
What this does is it moves the O2 sensor further away so a limited amount of exhaust gets to the O2 sensor, it is a VERY little amount that actually gets to the sensor but as long as it is considerably less than the primary O2 sensor then it wont cause a CEL.
So essentially you could just use the CEL eliminators that Jason Burtman sells and put those on the long tubes and it'll still pass emissions here?
Thanks again
Thanks again
Him, Ebay, or just make your own for cheap. Whatever you wanna do...
So you're gonna run no cats essentially? Are you worried about the smell at all? Or worried about getting a visual inspection during emissions testing and them seeing there's no cats?
All they have ever done is Plug it in. They have Never looked under it. As Long as No CEL's you should be Good.
Just a heads up for anyone in AZ in the future, Scottsdale Muffler and Automotive quoted me just $486 to install the DT Shorty headers and high flow cats on my '04. Including a free re-torque after 5-7 days! Sounds more than fair if you ask me, but thanks to some input from members on here I might be doing the long tubes instead.
Very Cool. Hey man we should hook up and Wheel some time.
I had to bring a vehicle down here from work for some muffler work. Chris the Owner is Very Cool. Gona talk to him about doing my headers when I get them.
Scottsdale muffler and auto is hands-down, one of the best places in the valley period. Chris is Awesome to deal with. My son put long tube headers Y-pipe and URD Cat Back on his 06 V8 Sport. We cut off the resonators on the Y-Pipe and Replaced them with Gesi Cats. Top quality work by a top-quality place. He will be doing my 4runner next. I may go dirty deeds exhaust. I cannot recommend them enough.
Thats good to know on the shop and emissions test. I could have sworn they hooked the pipe to my exhaust when they checked mine but maybe thats just for fumes. Dealing with all that is one of the reasons i havent done it yet.
Did you go with the titanium studs or just new stock ones? Also is there a reason you want to go short tube after your son went long tube?
Sent from my SM-G975U using Tapatalk
I'm going long tubes. I'm going to put GESi Cats in place of the Resonators to. That way, if there are any issues in the future with cats, they are much easier to get to then having to remove the manifolds/headers. The funny thing is they said the stock studs from Toyota are really good. My son put on the titanium studs.
