Best way to keep Xreas with a lift..
PanamaRed
This is what seems to me to be the best way to lift an XREAS 4Runner and keep the Xreas system intact..
Revtek front spacer kit, OME rear springs, rear shock relocator from NE ( welded into place) with drop bump stops to keep all of the shocks from being over extended..
How does that sound and can anyone think of somthing to add or somthing I might be missing?
ditto on the cornfed. that's the best way to go if you have xreas. cheap and easy btw.
don't even bother w/ NE's rear shock relocator as that thing is poorly engineered. search and you will read up on how that piece damaged 2 vehicle's xreas system.
good luck
I have seen that NE has not got a big fan club...LOL... But who else makes a rear shock relocator? Should I just make my own or what? I was thinking of making a bracket to push it down from the top so the rear shocks won't be over extended..
nobody else makes it because it's too much trouble to rework the geometry and keep it lined up perfectly. I'd say just stick w/ cornfed spacers and call it a day. it's the most you can do.
if you want more, then sacrifice the xreas and remove it.
good luck
There is absolutely NO reason to ever use a reloc ... especially from that company.
It has caused many people far more trouble and damage than if they had just run without them.
Elchele89
