BF Goodrich Mud KM/2 285/70/17
Twin Bridges
What's the correct tire pressure for this tire on a 2013 Fourrunner Trail with the the ulitmate Toytech lift kit installed? 35psi? Discount Tire said 50, that seems to high and the ride is rough with 50.
Best thing to do is work out the math. The MAX inflation pressure is what you should run at the maximum capacity of the tire which is listed on the sidewall. You're BFGs are probably load range E, which means your little 4R is probably only using 40% or less of the capacity of the tires. Therefore, you probably will have the best wear between 20-28 PSI depending on the weight of your rig.
7ron
