Big O Tire Alignment?
atalarico
Senior Member
Hey,
So my 97 needs a front-end alignment. Is there any reason to not go to some big box place like Big O Tires out here in Denver?
Some hate the big box stores but...
lifetime alignment still sold at Firestone and Tires Plus. Pays for itself about the 3rd alignment.
I like them but I find some shops are better than others. I use the Firestone at 80th and Wadsworth (Lake Arbor I think it is called) and they rock. I trust them to check out my front end and tell me what they think it needs. I drive past several other 'Stones to get there as they are run professionally.
Then I ask these great guys here and on Yota Tech to explain what they told me.
$10 off alignment sale I just saw at bottom of this very thread.
No 4wheel alignment needed on our Runners... just so you know. They do.
"no 4wheel alignment needed " is that for 3rd and 4th gens ?
the factory 4 link is non-adjustable. Now if you have an aftermarket lift with adjustable links or panhard bar then you might need a 4 wheel. Other then that factory only need a 2 wheel alignment.
The Big O Tires stores usually have the most up to date equipment. However, they will try to sell you several hundred dollars worth of maintenance. The easiest way to avoid this is to DRAW A LINE THROUGH THE NO CHARGE SAFETY INSPECTION THAT PRINTS ON EVERY WORK ORDER. And then sign it for alignment only.
Jhunt
