Ron_Mexico
Anyone know if 285/70/r17 would fit on a stock 2006 Toyota 4Runner??
No - its too wide and will hit the UCA. when turning you will hit the fender liner and possibly the body mount chop.
265 is as wide as you can go safely, 275 is a gamble
32 inches is about as big as you can go stock - 255/75/17s, 265/70/17s, maybe 265 70 18
If the 4Runner has a 2” lift would 285/70/17s work?
It's the wheels/offset that's the problem, not the lift.
Adding the lift will just change when the tires collide with something; going straight, turning sharp/shallow, full stuff, etc. The suspension will still cycle along the same path.
Changing the wheel width and offset can bring about solutions and new/different problems.
You're going to have do some significant changes to stuff 33's. That extra 1" of width betweeon 265->285 adds some complication to getting the tire to stuff without rubbing anything along the way.
