P0705 no start
Quinn_p
Junior Member
I’ve been having this constant issue with my 2006 Toyota 4runner v6. The issue was a no start after any drive or when the car gets up to temp then shutting the car off and coming back to turn it on and i get a no crank no start I also get a p0705 code only when its not starting (Transmission Range Sensor "A"Circuit (PRNDL Input). I used to get it to start i would just let the car cool down and then it would crank right up no problems but now the car has sat for a while and i charged the battery and it will not start at all unless i jump the starter. I'm just looking for anyone else that had a similar issue I've been stuck on this for months and I'm completely lost. I did also throw a starter at it but nothing only other thing i can think of is some type of wiring issue to the nss.
Are you saying the engine will not start but it is turning over or nothing happens when you turn the ignition switch to the start position?
Mike Sargent
