Billstein 4600s with LCs and tundra coils?
avenged yoda
Ok so I just bought billstein 4600 series front and back and I was wondering if I can put lc 8 wraps and tundra coils on these? I thought stock would be fine but I want more lift now!! If not ill just body lift and tires.
why not return the 4600s and buy the 5100s for the lift... and yes you can do almost anything you want, but will it work is another question. i would not run the LC coils with stock shocks,(im not even sure if they would be long enough) the tundra coils... im not sure if you could get away with that one either. but even if you could run both the LC and tundra coils with the shocks you just bought, you would trash those shocks in no time as they are not designed to work in that application
Like stated not sure if they would even be long enough in the rear and if you did get them on there they would over compress and stretch as soon as you flexed her out for the first time. He probably cant return them since he is using the shocks im guessing.
AlaskaRuss
