Bilstein 5100 or OME 60028 for rear 906 coils?
I have the front TRD setup and 906s out back...but I have the OME 60028 shocks...same difference since the shock gives no lift in the back.
IMG_3547.jpg~original
IMG_1996.jpg~original
what perch
What perch are you on with the TRD's up front? The one pic looks like the front is a little higher than I want and I was going to do the same setup.
I have the stock TRDs, so I don't have any adjustments. I believe that the stock is equal to the first or second setting on the Tundra 5100s.
If you
dont want any bro rake then use the 5100 first perch if your pairing with the 906s. For a little rake add 10mm trim packs to the 906s.
utkrstam
