Bilstein 5100s at 2.5” with daystar 1.5” rear
Srgagliardi
I’m going to be installing Bilstein 5100s all the way around and a daystar 1.5” spacer in the rear soon. Hoping it will look pretty level. I have 265/70/17 tires. Does anybody have any pics? I think it would look good I just hope it’s not going to make the tires look too small. Any input?
Here...
and...
Here...
The offset of your wheels will likely be the difference between “looking too small” or not. Factory wheels and 265s might look small. Aftermarket wheels with negative offset seems to change the appearance quite a bit, even with 265s. Just my 2 cents.
Yeah wheel offset will make a big difference, I use 265/70/17, right after my ome 883/895e lift was installed, my stance looked a bit skinny, but I threw on some SCS wheels and it made a huge difference. The new wheels stick out over 2.3 inches on each side over the stock ones! It helps that the Falkens are big for their size too.
Sent from my SM-G950U using Tapatalk
Sorry for the 5th Gen photos in a 3rd Gen post. I forgot which forum I was in. 3rd Gens are still my favorite on looks alone and I’m always stalking these pages.
My buddy's 2wd v8. Bilstein 5100s at 2.5 and stock springs up front, daystar 1.5 rear. Installed a few weeks ago.
Sent from my SM-G892A using Tapatalk
Well....
I had them installed a couple days ago and I’m happy with the way it turned out. Thanks for all your feedback.
Bilstein 5100s all the way around (front set at 2.5”) and 1.5” Daystar spacers in rear
Rides great
Thanks for the pic,
is this with the stock SR5 springs? or did you purchase any different springs with it? this is the exact look I am going for on my 03. I just purchased the following:
5100 Bilsteins all around with front adjustable.
2016 4Runner springs with 1k miles all around
and I have 1.5" Daystar rear spacer.
I was hoping to achieve the level you have with only the springs and not using the rear spacer, but now I am wondering if I should just add the rear spacer anyway and pump the front up to 2.5...?
Thanks!
Thanks for the pic,
Thanks!
No I didn’t change the springs out just left the stick ones on....for now anyways.
I know it’s off topic, but I just ordered these today! Can’t wait to put them on.
Post pics when you get them installed! I’m also looking at nerf bar options.
It was pretty easy to install. I would recommend using a socket extension when you put the new brackets on. Hold the nut with a wrench and use the socket the loosen the screw. You will have to have the socket in the reverse direction in order to loosen it that way.
I will post better pictures soon. I’ll take some in daylight
