Bilstein 5160 Rear Spring Recommmendation
MK_Ultra
Member
I just bought the Bilstein 6112 Strut & Spring & Rear 5160 Reservoir Set. I was wondering what you guys recommend for a rear spring? I would like to get anywhere from 1.5 to 2" lift overall and keep the rake angle I have now which is stock.
Main priority is ride comfort on the street. So far, I am considering these but do not know which one best suits my needs and works well with the above setup:
Metal Tech LT Springs Medium
Sway-A-Way Rear Coil Springs
Also, anything I may need to buy for the above set for installation?
I would go with Icon 2" springs if your rear is basically stock. I ran the 5160 + 2" springs for a year before swapping out to the Icon Overland 3" springs when I got my rear bumper. I could sell you my set for a good price since you seem to be a local. Hit me up on DM.
No need for the LT spring since you aren't running LT shocks.
Just get a standard rear lift spring from ICON, King, Fox that they use for their lift kits. The sway a way is a good option too. Don't forget OME too. Toytec has a good rear spring that people have been happy with.
Are you going to have weight in the back?
I run the 6112/5160 combo front set at 2.5” and rear 2” icon spring
Here is the front about 23” from center hub
The rear is about 25” from center hub I was holding the measuring tape with one hand so it was off by an inch.
As an aside this what my setup looked like when I was running 6112/5160 w/2” Icon Springs
I also had a third row back then (+100 lbs over stock) and still had a nice rake. The front coilovers were set to 2.5"
