Bilstein HD Land Cruiser rear coils.....?
quicksilvr
Bilstein HD Land Cruiser rear shocks.....?
I'm looking to go ahead and replace my rear shocks, since I'll be using 890's with a 1.5" spacer. I don't think my stock length Bilsteins will be very effective at that height.
So, I know about the Trekmasters (part number GE4095), and very well might use them. I assume they'll work fine with OME 890's.
But, I was on partsgeek.com, and figured I'd see what they had for rear shocks for the FJ80. They have two different Bilstein PN's....and I'm wondering two things:
1) Bilstein HD LC rear shocks should work pretty good with OME 890's, right?
2) If they would work well, which part number is the correct one? I can't tell why there are two different ones showing....
95 1995 Toyota Land Cruiser Shock Absorber - Suspension - Bilstein, KYB, Rancho, Monroe, Front, Rear - PartsGeek
EDIT: I changed the title of the thread, since I accidentally wrote coils. But it hasn't changed......
Thanks for the input on the HD's. I considered the 5125's. I was just trying to save some $$. The HD's are only $66/each, plus $8.95 shipping. So less than $150.
Basically, I'd really like to find some shocks that will work well with the 890/1.5" spacer combo, and not break the bank.
quicksilvr, have you found the GE4095 in stock anywhere? I've ordered it twice from two different places now and both, are not only sold out, but contacted Tokico directly and said they have none left in the US.
Nope, I hadn't gotten that far. However, I think I'm going to order the Rough Country shocks from Wheels Offroad. Affordable, and seem to have good reviews.
Rough Country Nitro 9000 Shocks from Wheeler's Off-Road, Inc
I am running the factory black Tokico Landcruiser shocks from a 95 Landcruiser. They are 38 dollars each at Toyota parts zone.
Part # 48531-69416
Part # 48531-69416
rj, do you have OME 890's out back? Your sig says SS7.2.....and I think that's what Steve sells for that kit.
Yes, mine started out as a system 1, but I had a crazy rake so I put the 890's in. The shocks seem to match pretty well with that coil. They are also beefier than the factory 4runner shock.
Ok, thanks for the info. I actually just ordered Rough Country shocks from Wheelers. But it's good to know the LC tokico's work nicely.
cool, i got LC 8 wraps, you guys think the stock tokicos would be better or the rough Countrys?
For on-road, and mild wheeling, the Rough Country's would probably be better because they are a higher quality shock when it comes to dampening. However, they are shorter than any of the factory size LC shocks. So if you were planning to flex the rear out a lot, then the LC shocks would be the route to go. This is just a hypothesis though....I can't be sure either way, since I have limited first hand experience.
