I first ordered a set of extra headlights (sabersport ebay) so i could retrofit them off the vehicle and keep the truck driveable. I then ordered a set of FXR projectors and HID's from theretrofitsource.com, who worked with me very well on getting everything right throughout this process. I baked the headlamps in the oven but this is where i decided to do things a little different. I removed all the factory glue from the headlamps and the lens, its VERY sticky and each headlight required going in and out of the oven multiple times, because the glue cools and thus hardens quickly. I used a 4" hole saw for perfect cuts, and drilled my holes for the FXR projectors. I was about to start making brackets when i decided to go a completely different route(add 3 days). I purchased a set of the Minimoto plug and play projectors and started the entire process over on the original headlights(also sabersport) that were on the truck. They provided a 3 pronged bracket that is the shape of the original H4 bulb base. You must tap this in from the back to get a perfectly flush seat. I guess they expect the tension to hold it in because the original clip is too chincy for me to trust and theres not any way to get it on properly with the rear of the projector housing sticking through. So i used 250 degree black epoxy on the front and rear of the bracket, fusing it to the housing permanently(add 12 hrs for epoxy to set). The new projectors slide in from the front and attach with a nut, but one of the housings threads stripped(add 3 more days for a new projector). The nut must be VERY tight otherwise you will get minor movement in the assembly. It also helps to use red locktite. I drilled a small hole just beside the main opening and passed through the highbeam wires, then sealed it off with black silicone. I waited around for night to come and mock tested the headlight pattern on the road to ensure alignment. After i was satisfied i filled the entire back end with black epoxy...the projectors will never be comming off the housings. Finally i removed the projector lens and cleaned everything off for final assembly. I sealed the headlamps with black silicone sealant(rated 450 degrees). No baking. Btw, the shrouds come free with the Minimoto projectors. Also, the H1 style Bulbs do not sit flush in their housings so you will need to take a file and go around the entire bulb base to get a perfect fit. You will also want to bend the clips ever so slightly for a more snug fit now that the bulbs are fully seated.
