Blackout Headlights
chaossd
I've seen a post on here before with instructions on how to blackout your headlights.
Can anyone help me find this post or give me instructions on how to do it? Anyone have detailed material selections (i.e. paint, silicone, etc.) too?
Thanks!
Here is a section written by spencer_hong from Tacoma World. I ran into it searching for 4R parts on google. Hope this helps.
Doug
Blacked out my headlights yesterday.. one of the sweetest mods on my truck.
I have an 07 Black Double Cab Pre-Runner
You'll need some tools and materials for this.
Phillips screwdriver
Flat-head screwdriver
Socket wrench
Baking oven
Black Krylon spray paint
600 grit sand paper
Rubbing Alcohol
Electric Tape
I am not responsible for anything you do to your truck! Although this is fairly simple, there are some things that could go wrong and if you don't think you can do this, dont try!
1. Removing grille and side parts under headlights.
First you'll need to get under the hood, undo all the pinch screws and philips screws to take the grille off. Then undo all the screws and one bolt for the headlights. Two of the screws are right on top of the headlight, while one is on the inner-bottom of the headlight. All these screws are grey. The last bolt is a pain in the ass, you'll have to go under the front bumper, and its way up on the outside part of the headlight. You won't be able to see it, but you can see a part of the grey headlight holding onto a bar. If you stick your hand up you'll feel two bolts, the highest one up is the one you'll need to undo. Get your socket wrench and take that sucker off. PS when you put your headlights back in you won't need to put this bolt back in.
Make sure you unplug all the lights connecting to the headlight. The running lights twist and pull, headlight socket disconnects just by pulling, and the blinker socket pushes in and disconnects.
Pull the headlights out.
2. Baking the headlights.
Make sure you take off all the little plastic and rubber pieces on the back of the headlights along with three small hex screws and take out the main headlight. Pre-heat your oven to 200 degrees F. I know the oven part sounds sketchy, but as long as you do everything right it'll work out perfectly. Stick the headlights in one at a time for 8 minutes. When you pull them out let them cool for a very short time then start pulling the lens away from the plastic backing. The sticky stuff between the plastic and lens is really strong, and trust me it might get frustrating (it definitely did for me) but remember, take your time. A flat-head might be useful he to help pry the two apart.
3. Once you get the lens away from the plastic.
Once you pry it open, you'll have to unscrew two hex screws attached the plastic chrome frame. Detach the frame, and pop out the two light panels. This chrome frame is what you will be painting.
4. Prep and paint.
To prep the frame, use the sand paper and get off as much of the chrome as you can. Then clean it using rubbing alcohol. Lay out the frame on newspaper or something, and get the spray paint. I suggest doing 3 or 4 light to medium coats and letting it dry 5 or 10 minutes in between each coat. After this you can pop back in the light panels, and screw the frame back into the lens.
5. Putting the headlight back together.
Put the lens w/ the frame back into the plastic holding of the headlight. Stick it back in the over (preheated at 200 degrees F) for about 5 minutes. When you take it out, immediately push it back together and get the silcone to stick as much as possible. The headlight should have a sturdy hold and not seem like its going to fall apart. It should be completely glued back togther. I reccomend using electrical tape to seal all around the lens, just so no moisture gets in (i had this issue). Put the headlight and grille back in, and enjoy!
