Phx994Runner
(sorry for the duplicate post - I added this in an earlier thread and I think it got buried)
Anyway, I need to replace the three brake hoses as they're visibly cracking. My question is - what is the process I should follow before I remove the hoses?
Do I need to follow the start of the bleeding procedure by pumping the pedal 40 times with the ignition off to de-pressurize the lines? I don't want fluid spurting out once I loosen the first hose.
Should I then just replace all three and THEN bleed everything, or do the rear first then bleed, or ...?
Lastly, does anyone happen to know what inside diameter (ID) plastic hose I need to fit the bleeder properly?
Haven't done this before, any advice/pointers welcomed - thanks!
