Some of these recommendations may work but the 2003 FSM says:
4. BLEED BRAKE LINE
(a) Connect the vinyl tube to the brake caliper.
(b) Ignition key is turn to ON.
(c) Depress the brake pedal several times, and then loosen
the bleeder plug with the pedal held down.
(d) At the point when fluid stops coming out, tighten the
bleeder plug, then release the brake pedal.
(e) Repeat (b) and (c) until all the air in the fluid has been bled
out.
(f) Repeat the above procedure to bleed the brake line for
each wheel.
Torque: 11 N·m (112 kgf·cm, 8 ft·lbf)
5. CHECK FLUID LEVEL IN RESERVOIR
(a) With the ignition switch to OFF, depress the brake pedal
more than 40 times.
HINT:
When a pressure in power supply system is released, reaction
force becomes lighter and stroke becomes longer.
(b) Remove the reservoir cap. Add brake fluid up to the
”MAX” line.
Fluid: SAE J1703 or FMVSS NO. 116 DOT3
The attached has the procedures for bleeding the MC if necessary.
THE 2007 FSM says:
BRAKE FLUID
BLEEDING
NOTICE:
Wash off brake fluid immediately if it comes into contact with a painted surface.
If the brake pedal is depressed with the reservoir cap removed, then brake fluid will spatter.
HINT:
If any work is done on the brake system or if air in the brake lines is suspected, bleed the air from the system.
When bleeding, keep the amount of the fluid between the Min. and Max. lines on the reservoir.
FILL RESERVOIR WITH BRAKE FLUID Fluid: SAE J1703 or FMVSS NO. 116 DOT3
BLEED BRAKE BOOSTER W/ACCUMULATOR PUMP ASSEMBLY HINT: Perform this step only if the brake booster with accumulator pump assembly is removed and/or installed.
(a) Turn the ignition switch off, depress the brake pedal 20 times or more , and release the pressure from the accumulator.
(b) Fully depress the brake pedal 10 times .
(c) Turn the ignition switch to the ON position and start the brake booster pump.
(d) Make sure the pump operates for 8 to 14 seconds .
If the pump does not operate as specified, repeat steps (a) to (c) and recheck the operating time.
BLEED BRAKE LINE
(a) Front brake line
(1) Turn the ignition switch to the ON position and wait until the pump motor has stopped.
(2) Connect the vinyl tube to the brake caliper.
(3) Depress the brake pedal several times, then loosen the bleeder plug with the pedal held down.
(4) At the point when the fluid stops coming out, tighten the bleeder plug, then release the brake pedal.
Torque: 11 Nm (112 kgf/cm, 8 ft. lbs.)
(5) Repeat (3) and (4) until all the air in the fluid has been bled out.
(6) Repeat the above procedures to bleed the other brake line.
(b) Rear brake line
(1) Turn the ignition switch to the ON position and depress the brake pedal.
(3) Loosen the bleeder plug and release air.
HINT: Brake fluid is sent through the pump, so keep the brake pedal depressed until the air is completely bled out.
(4) When the air is completely bled out of the brake fluid through the bleeder plug, tighten the bleeder plug.
(5) Repeat the above procedures to bleed the other brake line.
BLEED MASTER CYLINDER SOLENOID HINT: Perform this step only if the master cylinder solenoid is removed and/or installed.
(a) Connect the intelligent tester to the DLC3.
(b) Turn the ignition switch to the ON position.
(c) Select "ACTIVE TEST" mode on the intelligent tester.
(d) Connect the vinyl tube to the rear brake caliper.
(e) Loosen the bleeder plug.
(f) Select "SRMF & SRMR" to drive the solenoids and bleed air from the rear brake caliper.
NOTICE: Do not depress the brake pedal.
HINT:
Brake fluid is sent through the pump.
To protect the solenoids, the intelligent tester turns OFF automatically 2 seconds after every solenoid has been turned ON.
(g) Repeat step (f) until all the air in the brake fluid is bled out.
(h) When the air is completely bled out of the brake fluid through the bleeder plug, tighten the bleeder plug.
(i) Repeat the above procedures to bleed the other brake line.
(j) Turn the ignition switch off.
(k) Turn the ignition switch to the ON position.
(l) Clear DTC.
