Blinking 4wd lights
fierohink2
Junior Member
I have a '99 Limited A/T with M/M transfer case and e-locker with 121k miles. For about two years or so I've had a random blink of the 4 green 4wd lights while driving in 2wd mode. About a year ago, maybe less, the 4wd quit working and would not go into 4x4 mode either by pressing the M/M switch or shifting the j-shift lever into 4HI.
I thought it was going to be the switch on the front diff that seems to be a common failure. I have tested it, get good continuation for open and closed, but did not improve the function of the ADD.
Using the shifter does engage the front driveshaft. So I know the transfer case works.
I can apply vacuum to the two ports on the front diff actuator and get it to engage and disengage. So I think that actuator works.
I cleaned and tested the 2 switches on the transfer case actuator and they now have good open and closed continuity.
I have used information from another thread provided by [MENTION=10169]TheDurk[/MENTION] to do a series of tests at the F7 connection at the 4wd ECU.
I have also tested with a multimeter to find a functioning fuse.
I need help interpreting the data I have at this point. And getting direction as to what to check next.
This is the results of testing connection F7 at the 4wd ECU
pub
It's Fixed
omg omg omg
After trying the relay test to get the actuator on the transfer case to do something, anything and failing, I shopped eBay for a used transfer case and succumb to the realization that my actuator was fried.
Since I had nothing to lose. I took the cover off the motor on the actuator. I found the original grease all dried and caked up. The pads of the contacts on the cover were tarnished green.
I cleaned everything up, sprayed with contact cleaner, polished the contacts with emery cloth and reassembled.
Push the button and..............Kah-clunk......... the 4wd lights blink and the go solid. Backing out of my driveway I can feel the front push and grab from engagement.
Thank you to everyone that has write-ups, threads, pictures, etc.
A big thanks to [MENTION=10169]TheDurk[/MENTION] for uploading EWD pictures here and on yotatech.
PRWhite
