Bluetooth - Blue Logic and JBL system
Net4n6
I searched and only came up/confirmed Blue Logic bluetooth worked with Non-JBL system.
Did anyone installed Blue Logic bluetooth with JBL system? I need confirmation before placing the order.
What's about Parrot Bluetooth? Is it better than Blue Logic since Blue Logic installed as "OEM"?
Thank you,
Net
The Toyota page for BLU Logic explicitly says it "...conflicts with all JBL audio systems...". Maybe there's some other BlueLogic system you're talking about?
Parrot, Motorola, probably others can be made to work, but will require some effort on your part. They are intended to work by putting a relay between the amp and speakers, allowing the systems to work with radios with mute triggers...the relay simply switches the speaker connections from the head to the bluetooth's internal amp when needed. This presents a problem for systems like our JBLs where the amp is located separate from the head unit; no easy way to do plug-n-play at the back of the head unit. See my sig for a Motorola T605 install into a JBL Synthesis system.
-Brent
