Board vs. 4Runner: Paint Tips
PredBlue
Like the title says, Board vs. 4Runner....more specifically, a 2" x 12" fell and scraped across the front end. This is on an '03 and Silver in color. It left a softball size area of damage on the plastic fascia directly above the fog lights. I actually used a Magic Eraser and got about 95% of the color transfer off, and the few scraches that went more than surface deep I'll just have to live with since they're fairly faint. However, I still have an area about 4 inches long and 1/4 to 1/2 inch wide were the paint was scraped down to the bare black plastic that I want to touch up.
I've never been happy with the results I get from using the small brush that comes inside the touch up paint. It always seems to look a little "gloppy" when I've used it before, but usually it was a small area anyway. I tried a test on some scrap using the included brush vs. a small hobby brush (like for plastic models) and the hobby brush looked a little better (maybe because the hobby brush bristles are softer?). Still, it didn't look very good. Maybe the problem is just with the metallic silver being a harder color to work with?
Since this is a larger surface area on front, I would appreciate any tips, tricks or techniques for trying to make this look better. It's too visible of an area to try and fail so I thought I would ask for advice first.
Thanks.
Honestly the amount of tim and frustration you'd have to invest in trying to either rattle can it or brush touch it outweighs either PlastiDipp'n it or paying a body shop to fix it. Silver fleck is easy to lay down wrong and screw up.
Shouldn't cost ya more than $150 to respray at a jobber shop. me, I'd call it "PATINA". :lol:
For best results using touch up paint, its best to buff it and apply 2-3 coats in each spot, with buffing in-between. If you are brave, wet sanding it very lightly with high grit sandpaper will smooth it out more, and buff it yada yada. If you want more info, shoot me a PM.
AndiGarage
