Absolute
Okay, so a few weeks back I asked for some input on a body lift. Well I finally preformed the install and thought I would share.
I have never done a write-up before so any input would be wonderful.
To start you have to remove the front bumper. It is pretty easy. There are bolts on top and 4 on the bottom and snaps all around the front fender well.
After you remove the front bumper you will want to go around the car and pull the carpet up in the 6 corners inside 2 in the trunk, 2 under the rear seats, 2 in the front right corners of front foot wells.
After you reveal all the body bolts on the interior of the car you will want to remove your washer fluid reservoir. The top breaks away with no bolts, and the bottom comes out with 3 bolts. Make sure to remove the wiring from the unit so you don't break your clips like I did.
After you get that removed you will want to loosen your radiator shroud. There are 3 bolts that hold this in place just loosen them so you can wiggle the shroud.
After you get all that done you are ready to loosen the body bolts. You want to do this one side at a time, after you get em all loosened you are going to remove either the passenger side or driver side bolts, (not both at the same time, you don't want the body to slip off the frame. ) After you get the bolts removed you will jack the side up use a 2x4 to distribute the weight under the body. Insert the spacers ONTOP of the body mounts. (so between rubber and body) then put the bolts through, after done lower jack and put the nuts on. Repeat on other side.
I ran into one problem with my ToyTech 1" body lift. My radiator fan hits my shroud. It is usable, I will need to order a radiator drop and install it asap though.
Make sure you get all the bolts good and tight!!! I will be adding my steering spacer this weekend. If you have any questions feel free to ask.
