i just capped off the front opening with rubber pvc cap,i thought about running pipe/hose, but with so many bends youd have to make, i dont think its worth it. but i widened the hole in the fender 1/2 & ran a rubber coupling thats used for pvc sewer pipe out, threw fender, it fits snug enough so no chalk or anything else is needed. if you ever reinstall the stock box, you wont see it. 2 black plastic folgers coffee can lids , 1 inside box, 1 outside, & foam insulation were used to seal the inlet tube to TB, thats the important one to help keep the hot engine bay air out. the volant dry filter ( universal round) draws airs from the front/top only, & that lines right up to the box inlet hole. all this makes a pretty good seal & the now the volant a true cai . my STP dyno says these mods really help . to me , it makes the volant look like it should. you also wont hear the loud sucking sound like the k&n in case you dont want that. the dry filter is $, it cost 10 bucks for the other stuff. by the way,i went about a year after the install before the wet volant filter fouled the maf, which i replaced with a jet hiflo one,(could of just cleaned it, but didnt want to chance it) the engine can just cut off while driving.(yes that happened) but there are some guys that never develope the fouling. pm me if your interested in pics. the filter is the Powercore, 3.5 x 7 x 6 round, i think # 61510, but when you click on it, make sure.
