Bought a rust bucket... need assistance (pic heavy)
nolo
Bought a rust bucket... need assistance (pic heavy) (UPDATED PICS in OP!!!!)
First off, I paid $6900 for a 2000 4 runner 4wd, v6. Engine and interior in perfect condition.... so what's the catch?
Well, the underneath is rusted. Badly. Can't change the fuel filter b/c the nuts/bolts are rusted that looks like a weld. Will need a workaround for that later...
biggest question is rear axle, differential housing. i don't hear any weird noises or anything, and everything works perfectly. I would like to change all the fluids and do typical maintenance on it. The bolt on the rear diff is rusted and i have not even attempted removal. Flakes of rust (a few millimeters thick) you can actually pull off the rear diff. it's in bad shape. Here are some pics, but most of the rust i've pulled off (seriously).
I am thinking of just replacing the rear axle completely. I think i am using the wrong terminology, so whatever i'm search for is not pulling up. Is this not the rear differential? How do I go about getting a new one or at least a new housing? Should I replace the rear axle as well?
UPDATE! Success in removing stuck bolt! I bought the Irwin Bolt removal toolkit off amazon.com (in 24mm) and used a large breaker bar to get it off. My buddies electric impact wrench wouldn't budge it. Fluid was pretty bad, but not many shavings on magnetic bolt. Here are some pics:
New Fuel Filter i installed:
transfer case: already changed this fluid. bolts came out easy, and it was relatively clean.
Diff bolt out, tools used: breaker bar, 24mm bolt-out socket, aero kroil penetrating oil
New bolt, messy driveway! I had a bit of a hard time getting the magnetic bolt out on the bottom, but damn when i gave (i used the impact wrench) i was not prepared for the bolt to come completely out.
thats all surface rust mines the same way. if you want it all gone sandblast it
how about attempting to back out the fill plug on the rear diff? looks too rusted and would HATE to break it off in there. Do you know of any fuel filter work arounds? I don't think it's possible to replace the fuel lines w/ flexibles (even though i've searched everywhere for them) and the nuts on the fuel lines are bonded to the filter.
even toyota dealership told me that they wouldn't attempt the filter :mad:
It "Looks" pretty ugly down there but might not be as bad as it looks if that makes any sense. How many miles are on it and what option package is it?
If it drives nice and nothing is falling off I would likely just leave it as is and drive it until something important actually does break and fall off. Do you know the history on why its so rusted down below? Looks like someone drove it in the ocean but it could just be from a snowy place where they use lots of salt. Japanese steel rust pretty quick.
As for the rear diff drain plug I have seen worse and people have removed them. Might try a penetrating oil like PB Blaster first to clean it up. You might have to take your time with it though.
angle grinder with a wire brush wheel will take most of the rust off. then spray paint the parts to provide a tiny bit of protection.
and buy a few cans of pb blaster. it will be your best friend when working on rusted out bolts
x2 on the Pb blaster, couldnt of changed the 3rdmember w/o it
and when you're changing your differential fluid
:awais:ALWAYS REMEMBER TO REMOVE THE FILL BOLT FIRST:awais:
the fill plug is the one you see when you look at the diff from the rear of the truck, located on the side of the housing.
You may be wondering why I say this. Well, if you take the drain plug out first, and then the fill plug breaks in ther housing, and you can't replace the fluid, you'll know exactly why...
thanks for the replies guys. It's a 2000 sr5, with about 126k miles on it. it was a northern vehicle, but i purchased it in louisiana. i did not take it to a toyota dealer first before i bought it (kicking myself for that), but bought it at a dealership there.
i will do some rust remediation this weekend if i can get away with it, and i will definitely take the fill bolt out before i take the drainplug out. I'm going to get an extra fill plug just in case i destroy this bolt.... looks fragile.
other than the rust (interior is perfect, as is exterior) the truck is great! OH, and i have that stupid gas gauge issue.... grrr... not too worried about that. gonna do a spark plug and fluid change and will post pics of the underside when i clean it up a bit.
where though would i buy parts like the diff case and axle and all that? i have searched everywhere...
thanks guys!
Hi, I live in canada and here we only replace the fuel filter if we experience problems with the vehicle. You could use some Toyota penetrating fluid on the fitting if you want to try it anyway, it's awesome what that fluid can do.
I would'nt worry about that fill plug, if it's too tight take a chisel and a hammer and make it turn counter clockwise, I've never seen a plug break. Worst case scenario would be replacing the plug because you did some damage to it with a chisel.
yeah, the guy asked me if i had problems with it and why would i want to replace it? if it aint broke don't fix it... i know.... i just like new parts, so i want to change it, and i'm assuming that it's never been changed, so that means i gotta at least attempt it!
i ordered the fill and the drain plugs just in case. i have a can of kroil penetrating oil, which is supposedly pretty good stuff for rusty things, just need the time to do everything in.
i put the tag on it today and the darn bolts won't even thread into the rusty back license plate bolt bracket! :bash:
So I attempted the rear diff today. no luck. the 24mm bolt rounded off (and yeah, it let it soak with kroil penetrating oil for a few hours) and can't get it off. I even took vice grips and attempted to bench press the back of the 4runner. No avail. It is bad guys.
I however did change the transfer case fluid, and it looked brand new, so i'm hoping that whoever had this rusty beast before me changed the fluids regularly. OH! And i changed out the fuel filter!!! Toyota wouldn't do it for me because they said it was too rusty... but I did it carefully and I got it switched out. Awesome.
nolo
Ok now try the naval jelly I recommended before. It may not work, but it's worth a shot. The nice thing with the naval jelly is that it dissolves rust, which just breaks away with enough force. This should leave you with clean metal to bite into instead of crumbling orange crap, as well as possibly breaking the bond between the plug and the diff.
