Bouncy Truck
mrrab
Bouncy Truck (VSC, VSC OFF, ABS)
UPDATE: After installing the shocks yesterday, I turn on the vehicle and low and behold VSC, VSC OFF, and ABS lights are on -- CRAP! Unfortunately, I was doing both side at the same time to I can't really pinpoint it to the right or left side. Anyone have any recommendations on how to most efficiently diagnosis.
I've heard about zero point calibration, disconnecting the battery terminals, some brake light switch, etc. I'm think I may have over stretched a wire. Specifically the VSC wire.
Also, some XREAS fluid got on the sensor portion. Would that have triggered these codes? I'm think not because the sensor is constantly exposed to the elements.
About a year ago I installed Daystar’s 2.5/1.5 spacer lift. During the install, I accidently loosen a bolt to one of the XREAS lines while installing the front right spacers. Wasn’t happy about that, but was hoping the system would still be intact.
After the install didn't notice a difference in ride quality from stock.
Then in August of last year I installed 895E’s to give my truck a tad bit more rake in the front as the 2.5/1.5 spacer kit damn near leveled out my truck.
After installing the 895E’s, which are advertised as being 10% stiffer than stock, I noticed my truck was unusually more bouncy than before, i.e. stock and with the Daystar 2.5/1.5.
Questions:
1. So, at ~125K and 9 years later (2004, V8) are my shocks going out? Bought the truck with ~115K, so don’t know what the prior owners did with the vehicle.
2. Did opening the XREAS system cause the shocks to fail? Wouldn’t think so.
3. Did the stiffer springs accelerate the failure of my shocks? I got the preload spacers in front and the 895E’s in the rear.
4. Should I get an alignment after I install the shocks -- not changing anything? Got an alignment last time I did the lift.
Regardless, got 5100’s on order.
I think your new 5100's should get the job done. Shocks are supposed to be replaced every 50k, but hardly anyone does. If the xreas lines are opened the system can fail...
I would get an alignment afterwards. Are you going to set the billies at 2.5 in front and remove spacer?
Hmm, you know I didn't give that consideration. I'll have to think about that. I really like the stance of the vehicle as it sits now. Plus, I have the preloaded spacers in front, which probably gives me a stiffer spring. Also, the Daystars gave me a 3" lift up front.
Maybe you could find some fj springs or aftermarket for up front, that would give some extra lift. Post pics when done.
The ONLY people I ever heard give a recommendation on shock replacement interval are people who sell shocks. I've NEVER EVER read in any owners manual for a vehicle I've owned over the past 30+ years recommend a shock/strut replacement interval.
Shocks/struts failure has a lot to do with driving style and where you drive. There is no time line associated with the replacement. I've had shocks that were well past 200k miles and still working PERFECTLY.
My trac lights came on after daystar, zero point calibration should take care of it.
Did your ABS light come one? Also, when performing the ZPC, how exactly do you short those two terminals? Can you use a paper clip?
Jhunt
