Brain storm, make my truck tweaker proof
t4r4life
Elite Member
i live in norcal the home of tweakers, and i saw this online today and it seems pretty interesting.
how would one do that to 4runner windows. all 7 of them not include the windsheild.
seems like you can get thin rubing and bend it and rivet some threads onto the body and bolt it in.
Tweaker proof huh?, you may not be a meth-head but if your thinkin about goin this route, selling the rig is probably your best bet
Sidenote: make sure you're able to get out (without power) if you flip the runner or end up under water...
Buy lexan. You can get it shaped to replace your oem windows and its unbreakable. It's commonly used on track cars.
Only downside is that on your rear, the wiper will scratch it. It will also turn a little hazy and yellowish over the years.
Isn't (lexan, in the right thickness) also bullet proof ? You could make it West Oakland proof as well.:guitar3:
Yeah but you'd need 1/2" or thicker which would be pretty much impossible to shape onto the OEM windows - at least in terms of a DYI project. 1/8" is the thickest I'd try. In general, you'll see 1/8th side windows and 3/16th windshields made out of lexan - but you probably need DOT approved windshield so you can't do that anyway.
OP
I've thought of something like this for TSHTF scenarios. The best way I've come up with is putting it on the outside of the window and making a top support that you could roll up in the window, pinching it in place. The lower portion and middle would be supported by suction cups. (Yes I realize the suction cups are not the best support but it would mainly deter against thrown objects and would make it removable.)
For the rear side windows I am going to build bars across the window using 1" square tube and expanded sheet metal. It will double as protection in TSHTF scenario and for wheeling. I bet no has seen someone loose a rear side window while wheeling right?
For the rear, I don't have an answer, yet...
The Vehicle Gard stuff seems great but that's $500 that might stop a brick IF I install it right and IF it does what the company says it will. I KNOW that metal stops bricks.
Kurtis
Speaking of protection from tweakers you put some over the cat to prevent someone from cutting it off quickly.:flamethrwoer2:
True tweakers are hard to stop.
Seal off the entrances with sheet metal, add latches and hinges like on camper shells so you can get out. . Use a series of cameras and LCD screens for navigation.
I am going to bolt a sheet of steel from frame to frame to make the ultimate skid plate.
You need the change the title of this thread. Should be "Your 4Runner and SHTF". All about mods done to to survive when Obama gets reelected.
Mike Sargent
