J jjbean New member Feb 15, 2011 #1 I own a 97 and recently the break pedal goes almost to the floor when pressed. i can pump the breaks and build pressure but wondering how to tell if it is the master cylinder or the booster pump. i'm pretty handy but is either a job i can tackle
fourwd1 Moderator Feb 16, 2011 #2 Sounds like an internal leak in the MC. If you replace it be sure to bench bleed it first.
fourwd1 Moderator Feb 16, 2011 #3 Sounds like an internal leak in the MC. If you replace it be sure to bench bleed it first. And BTW, it's BRAKES, not BREAKS.
fourwd1 Moderator Feb 16, 2011 #4 Sounds like an internal leak in the MC. If you replace it, be sure to bench bleed it 1st. And BTW, they're Brakes, not Breaks.
fourwd1 Moderator Feb 18, 2011 #5 ^^ Now that's really strange, I have no idea why it's there 3 times and they are different
