Brake Fluid Capacity?
I plan on flushing/changing my 07 2wd 4.0 T4R brake fluid. I'm going to use some fancy amsoil brake fluid,but haven't found a capacity listed anywhere. Anybody know how much fluid is needed so I won't have to overestimate and buy extra expensive voodoo juice?
Uhmm... How do you plan on flushing it? Because you want to be careful about letting air into the system as it will be a pain to bleed.
I would guess maybe something like a qt or two should be enough for a good flush if you just crack the bleeders and let it gravity flush while keeping the MC topped off.
I just had this done 2 weeks ago, i purchased 3 bottles from toyota, used all of it. First i pump my brakes 40 times with engine and key off, siphon the old fluid with a baster, then add in the fresh fluid, changed out the rubber lines to stainless steel, then the flushing and bleeding started, rear right, rear left, check the fluid level and added more, then front right and front left and topped it off.
Laredotx
