I took my car to the mechanic. These guys are friends so they hooked up with all the maintenance I needed. Got new brake pads (front and back), new rotors, new struts, new shocks, new arm bushings, and a few other things that wont relate to my problem.
But anyway, car was braking like never before for the first 2 days, I loved it!!! Then I was driving on the 3rd day and hit a pot hole, and I doubt this is what caused the problem, but my brakes were never the same after that.
Now when I press the brakes, I have to press it in all the way, passed the air cushion, then it finally brakes when the pedal is all the way hitting the ground. The braking strength is still amazing, but I have to press it in ALL the way for it to brake. I took it back to the mechanic and he bled the brakes again. Drove it, it got a little better, but not that much. He told me it is the master cylinder and I need it replaced. He showed me that when I pressed the brakes, the little rubber nipple on the brake fluid tank would pop out and make noise like it was releasing air.
I complained about how it could be a master cylinder, and how all of a sudden when all this work was done on the car that the master cylinder decides to go bad, it cant be a coincidence that this happens right after they did all this work. They took it offensively and now I am stuck with no friend mechanic and don't know what to do, or who to trust. Any advice would be good. Thanks in advance
