Brake pedal travel?
rileyb76
Guys,
We just got my wife a 5th gen SR5 2wd. I drove it around this afternoon and compared to my 4th gen T4R, the travel of the brake pedal seems very very long. For those that have had the 4th and 5th, can you comment on this? Is this something that is somehow adjustable?
Fwiw, hers is an '11 with 29k miles on it, so its under warranty still for a bit longer.
TIA
Theres been threads discussing this before. I never would have even known about it if not for reading this forum. I guess that makes it a non issue for me. I don't evennotice it and the brakes are fine imo. Some dont like it. Maybe moving the seat up?
I don't believe its a seat issue. I'm talking about the length of travel your foot has to press before the brakes engage. It just seems alot further than my 4th gen - or maybe something is out of whack.
Just a safety concern on my part. Her old Rav4 had a lot of brake pedal travel too, but its doesn't *seem* as far as this 5th gen.
Ya get used to it. I always drove a stick before and needed the seat alot closer for proper clutch operation. Maybe the reason the pedal travel doesn't
bother me.
I don't think its adjustable I would test drive another 5gen and see. My wife has a
5 gen and my is a 4 gen I think her pedals are far better response than my.
There's an extremely subtle point where the brakes actually engage during pedal travel on the 4Runners and its easily missed; usually within about 1/4 ~ 1/3 of the pedal depression. I mentioned in another thread that Toyota really shouldn't have made the brake feedback so soft because it throws off a lot of drivers off with how consistent the pedal is. You can literally push the pedal to the floor without feeling any significant change in resistance, but the brakes will engage and even over engage if done quickly (as many 5th gen owners have commented on this forum). This disconnection between pedal engagement, feedback, and brake engagement tends to confuse and disorient many drivers as a result.
Most owners are used to traditional braking systems where pressure built up in the master cylinder is fed back to the driver as a stiffer pedal the farther it is depressed. With the hydraulically assisted systems the way the system is designed and the effectiveness of the hydraulic assistance is so great there is little to no real feedback. This was an issue with the Prius and there was a software update for the 3rd gens to firm up the response of the pedal, because the first 1/3 of travel actually does nothing in terms of engaging the brakes hydraulically ("light braking" in a hybrid is done through the regenerative braking system mainly, after 1/3 pedal travel the brakes operate normally in conjunction). Toyota needs to adjust the programming in the system to allow more back pressure to build up in the master cylinder portion of the system and provide a better simulated feedback in my honest opinion...
But then again, many soccer moms tend to drive our vehicles, so I guess that won't be happening...
You get used to it, but it did bother me for the first month to be honest.
I actually had the ABS kick in for this jackass that pulled out right in front of me last night, worked like a charm.
lindwlson982
