brake problems
justbowser
greatings all i have a 96 4 runner love it finaly had to replace front pads and rotors anfter 196k miles now all i get is greef. ater driving just 15 mins the front brakes apply them selves and bring me to a complete stop i get out and pop the bleeder valves they let go then it happens again same thing i have replaced the vacuim line and the 1 way valve on the big vacuim thingy behind the master cylinder this worked for a day and now its back to every 15 min no matter how you are driving stock calipers pads and rotors are from orellies help any 1
Did you replace the rubber brake line hose at the caliber? Sometimes the interior hose section collapses and blocks the fluid from returning to the line causing pressure to be constantly applied to the brakes.
If it bleeder valves relieves the pressure I'd suspect that is the problem.
They are around $20.00 each down here.
