Brake repair - I'm an idiot
vachss
Member
OK, so when I recently bought my 2004 SR5 I noticed a strong pulsation under hard braking (and got the seller to drop the price accordingly). I've felt warped rotors before and was sure this was the problem. No big, I ordered some rotors from RockAuto and slapped them on... and... (you experienced 4th Gen guys know what's coming)...
found a seized caliper (and a nastily unevenly worn pad right next to it).
Now ordering and installing new (reman) calipers and pads is no big deal, but I'm kicking myself for probably wasting money on rotors. The ones I pulled out were 26.7mm thick with a min thickness of 26, while the new ones were 28mm even. So I figure I could have run the old ones for quite a while yet.
Anyway, I'm consoling myself that rotors/calipers/pads is the "right" way to do a brake job, but still feel foolish for my off the cuff - and wrong - diagnosis.
PS. Just getting Centric everything (rotors/calipers/pads). I've had good results with them in other vehicles, but would be willing to try something else if the accumulated wisdom here says another brand is better.
If it were me.....id use this as an opportunity to run the newer 5th gen stuff.
Would I need to upgrade to 17" wheels if I did this? I like the idea of the newer calipers, but if so this would be a pretty expensive mod all in.
Hey, while you are at it, throw on stainless steel lines if you don't already have them! The do make a difference....
I just did a total brake job on my rig. Found both front callipers seized. When I went to Toyota to get new ones they mentioned that they have corrected issue that caused the seizing with a new design. Ultimately talked me into sticking with 4th gen stuff.
So the choices so far are:
Gen 5 calipers (and new 17" wheels and tires). Total price, something over $1K even if I find a killer deal on wheels/tires.
"New and improved" Gen 4 calipers - which I guess I would have to buy new from Toyota for something like $250 a side.
Old and unimproved remanufactured Gen 4 calipers that I can get for about $60 a side from Rock Auto (after core return).
Given the prices I'm kinda leaning toward door number 3, but still would like to know the consensus of the crowd around here. I was pretty well versed in 4Runner repair on my old '86 Gen 1, but really don't know a lot about the subtleties of the newer models.
Some guys get their 4th gen calipers from NAPA. The calipers have a lifetime warrantee. That way, if and when the calipers seize again, they can get new ones at no cost and no shipping is involved.
Jhunt
