I had a few minutes, and already had the pictures, so I'll make it easy for you...
Here's your write-up!
Take off your wheel, and you should be looking at this:
Next, remove the bolt marked in this picture....
Ignore the pliers and the clamping of the brake line... (I had to re-purpose these photos from my tundra brake upgrade thread). Once you have removed the bolt pictured above, the brake line will be allowed some movement, which allows you to remove the caliper without disconnecting the brake line.
Next, remove these two bolts....Again, ignore the fact that this is a Tundra caliper, the mounting bolts on the stock calipers are in the EXACT same spot...
Once those bolts are out, the caliper can be removed... Pull it off the rotor, and use a wire coat hanger to hang it from the upper control arm or another convenient spot. The wire coat hanger can be bent into a double ended hook and is plenty strong to support the caliper.
Now grab the rotor and pull it off. Smack it with a block of wood or a rubber mallet if it's stuck on there.
Put the new rotor on the hub. Put two lug nuts on to hold the rotor in place.
Put the caliper back in place and put the bolts back in.
Put the bolt holding the brake line to the spindle back on.
Put your wheel back on.
Make sure everything is properly torqued...
That's it... you have just replaced your rotor. :trophy:
If you are replacing the pads, do the following before you put the caliper back on... (IGNORE the A, B, C, D, and all the red arrows)
Remove the wire retaining spring circled in green...
Then slide out the pins circled in yellow (there are two pins, I only circled one, but you can see the other one on the right) along w/the pad retainer (flat piece of metal shaped like a cross w/a curve in it)...
Put a c-clamp on the caliper (one side on the outside of the caliper, the other side on the surface of the pad) and use it to compress the pistons back into their seats to make room for the new (thicker) pads. Watch your fluid level in the master cylinder, it will go up as you compress the pistons, and you don't want it to overflow.
Now remove the pads in the direction of the blue arrows...
Re-install the new pads by reversing the sequence. Use your old pads as a reference for how to install any shims that come w/the new pads.
Then put the caliper back on the rotor and finish out the sequence above.
Any questions?
