Brake Service Advice
nicheel8
Member
On Saturday I’m planning to do the following services and would like some advice on which order would you do them in? Front, rear, brakes then bleed, etc.
1. Replace all 4 rotors.
2. Replace pads.
3. Bleed brake fluid.
I'd do front first (rotors + pads), then move to the back, start bleeding from the passenger rear first, then driver rear, passenger side, and last driver side.
If your not replacing calipers and just compressing the pistons back for new pads, then there's no real need to bleed them.
Given the issues the 4th gen calipers have, I would think bleeding them during a brake job and putting new fluid in there is a no brainer.
Remember its a different bleed procedure for the rears.
Personally, I'd start in the rear if you're hitting all 4. Replace parts, bleed, move on. Don't need to touch everything 2x.
I see AZ in your profile. If you lived in the rust belt, I'd say you're better off not bleeding. 50/50 chance the nipples are probably seized and you'll just hate yourself. Just replace the calipers when needed.
Good stuff. Thanks everyone.
She has 150,000 and since I'm the second owner I don't know if the brakes have ever been bled.
Yes, it's been in AZ it's whole life. When i upgraded the springs I didn't have any frozen parts. Everything just came off/on without issue. I even took back some parts I purchased just in case.
just did my brakes a few months back. BEST advice i can give is USE the RIGHT grease for the brake pin slides!!!!!!!!!!!!!!!!!!!! do not use anti seize grease. use specific brake pin slide grease, there are other alternatives that i did research but use grease/lub that is for the brake slide pins. i used anti seize grease causing the brake not to compress smoothly which caused a seirging pulsating feeling.
other than that it is not a very complicated job and can easily be handled by the weekend mechanic. i did it with my 10 year old son. he was stoked to wrench w me!!
good luck!!
http://www.toyota-4runner.org/3rd-gen-t4rs/228213-what-kind-brake-grease-should-i-using.html
Brake Caliper Slider Pin Grease - Toyota Nation Forum : Toyota Car and Truck Forums
Do not use brake grease on your caliper pins - Toyota Sienna Forum - siennachat.com
good luck!!
Thanks for the info. I changed the rotors, brake pads, stainless steel hoses and bled the brakes. Everything went well until I jammed a screwdriver into my fingernail. :Cry: It is throbbing.
tuṣṭāva
