Usually the squeek is from deposits on the rotor. The reason it is only in reverse can be a couple things, the low speed.. and usually people reverse their vehicles first, before going forward(backing out of parking spots/garages).. speed(heat) removes the deposits.
I would not worry about it.. if you are truely anal about it though, you can easily remove the pads and apply anti-"squeek" compound to reduce the noise.
