Bridgestone Revo 2 Review
Vizwar
Old tire: OEM Dunflop 265/65/17 ~23,500mi
New tire: Bridgestone Revo 2 265/70/17 ~400mi @ time of review
Mounted Appearance: Subtle. They don't pop visually like an M/T but the sidewall design is nice and the tread shoulder is visible enough to make you ask yourself "what tire does he have?".
Dry Performance: Sticky. In a good way! They hold very well to dry pavement. Some have described these tires as "darty" and I can see what they mean. They bite so well and hard that they are easily influenced by the crown in the road. It just takes some personal habit breaking to not over-steer a lot like the old tires required.
Wet Performance: It was raining, and hard... but I couldn't tell. When hitting standing water I felt more resistance than I would have expected but overall it was very acceptable.
Ride Quality: Oh wow, so much better. They are very quiet and stable. It's amazing how much a tire can change the quality of the ride. Since they are new tires there is some "float" feel but this is normal. It's simply because I'm now standing on a full length of thread that will flex some at first.
Stopping: There was one panic break done as a result of real world circumstances at congested highway speed. There was no skid and ABS didn't even consider getting involved. I stopped much sooner than I expected.
Upsize Experience: I was nervous about doing this but I'm quite happy with it. There was a noticeable increase in ride height, both looking at it externally and from the driver's perspective. It's not a lift by any means but a nice bonus. The 265/70/17 was LESS expensive than the OEM size too. There is no rubbing under normal operating conditions from stop bump to stop bump. I did not get a 5th tire to replace the spare but it should fit without any problem.
Other thoughts: I don't have any off-road experience with them yet but I will update this thread as soon as I do. Snow should be headed this way soon too. I suspect accusations that this tire is a mild A/T might be at least somewhat accurate. It's not an M/T obviously but I fully expect this tire to do very well in the mountains despite it's street look. If you want an M/T, buy an M/T. If you want an A/T (all terrain) that does it all then this I believe qualifies, as it appears to cover all terrains pretty well with maybe a little extra design emphasis on the pavement to and from the dirt.
Purchased from Firestone (dealer), Kirkland WA @ $701 for 4 tires (mounted, balanced, installed and tax).
Did you purchase a standard P rated tire or the LT rated tire?
It's P. I don't tow huge loads or haul loads of gravel so it doesn't make any sense to get a tire that weighs more just to get an "LT" on it. MAYBE if I did more off-road time but a heavier tire isn't going to flex aired down like you'd want. amirite?
Do you have any pictures, I've been trying to find 265/70/17's on a 4Runner with no lift since I'm looking to get Revo2's and can't decide on the size. I'm glad you posted about how the ride is with the larger tires, it's not slower stopping or accelerating. I'd also probably get a new spare too if I up size.
Interesting how you felt a lot of resistance from standing water. That's my main focus, wet traction and then just ride / look quality. No off roading for me either.
Thanks.
Other than feeling slightly higher, can you feel a difference in handling with the larger tires? Like cornering for example? What about accelerating and braking - do you feel you have to punch the gas/brake harder to get them rolling/stopping?
I am interested in an update later on regarding any rubbing issues without a lift in situations like turning over bumps or at the the bottom of ramps when one front tires getting really compressed.
Thanks for the review. I am looking at new tires and considering going up to a 70 series without lifting.
Every aspect of the tires are an improvement over the old Dunflops. Also keep in mind that the increase in size from OEM to the 70s is only 5%. If you want a larger tire, ignore your analytical fears and get yourself some bigger shoes. You'll really enjoy them.
I'll see if I can get some pictures up but there isn't much to see from a 2D pic I imagine. Again, it's only 5% taller than the OEM. :D
I've already gone over some curbs and speed bumps looking for rub and there hasn't been any. One person posted in another thread that they got some rub with 70s while backing over a large object but that was with a different tire entirely.
Actually I think it is only a 3% increase. 30.6 to 31.6. I current have the Cross Terrains, which are already better than the Dunlops. I do remember reading the other post about the rubbing in reverse. Those might have even been the tires I am thinking of getting, the GY Silent Armour. I want to go bigger for the slight improvement in clearance offroad. I can live with the MPG drop, but can't live with rubbing. I run tire chains sometimes in winter, and offroad trails that occisionally lift tires on one side while compressing the other side. I guess like many people I want everything. Good highway performance and good offroad. I figured going up in tire without a lift was the cheapest easiest way of imporving offroad performance with little impact on highway driving. So far you are confirming this which is great. I should also note that I am very conservative when it comes to modifications and alterning stock configurations.
yea we need some pics. I want to see how the new revo 2 look on the car. I'm also concerned on the less aggressive look of the new tire.
Revo 2 Review Cont'd
Today was the worst ice of the season and also my new tires 1st experience off road, though unintentional.
No tire is very good on sheet ice. Without something jagged to bite to the ice you'll always struggle. Even so, there are some tires that can perform a small step above the others.
In my office parking lot the ice was exceptionally bad and nearly invisible. I started down a shallow hill towards my parking spot and began to apply the brake. ABS started immediately, I went past my space and continued down to the edge of the parking lot where beyond the curb was a drop to a ravine. With ABS pounding for about 100ft and no reduction in speed I hit the curb, popped up over it and went down. The second the tires hit dirt I stopped. I had already been in 4Hi but that wasn't enough to get out. I was sure I was stuck. Half my truck was in a bush. 4Lo and locked the diff in Reverse and I was able to wiggle out and popped back up on the parking lot. Two employees saw this happen and were scrambling across the ice to get help because they thought there was no getting out. We were all amazed that the truck could back up that dirt incline covered in ice so easily.
So while any tire will have problems on 100% sheet ice I think the Revo 2s on par with other tires in this realm. Many other drivers crashed in to various other objects that morning in the parking lot so it wasn't anything unique to me. The tire's ability to grab on and get me back out of that incline was amazing! Saved me from any more embarrassment.
I'm willing to bet the fact I upsized to 70s saved my front air damn from smacking anything in the impact with the curb.
Today was the worst ice of the season and also my new tires 1st experience off road, though unintentional.....
:bravo: Good report! I agree, until you're into dedicated winter tires like Blizzacks, Nokians or similar there's little hope when on sheet ice. Glad you're ok and the 4Runner doesn't have new scars:bigok:
Thanks! :cowboy: I'm waiting for the ice to melt and I'll test drive it. I'm sure it needs some scratches waxed out and maybe an alignment. I tried to hit the curb as square as I could but the right front still tapped first.
