Brightest bulbs for corner lights 97 4runner?
Atreyus
Anyone know where I can get the brightest white or blue corner lights (194) for a 97 4runner? Any lights and type information would be greatly appreciated!
When I switched out my regular halogens for some silverstar ultras I had the same issue. I ended up looking around my local Kragen Auto Parts and found some blue bulb import lights that were the same size as the original corner lights. They burn a white color and match my headlights almost exactly. Think they were like 4 bucks maybe.
i ditched the 194 bulbs drilled the corners out and stuck these 68 smd led bulbs i got off ebay for 25 bucks they got a slight blue hue to them though there soo bright i actually had to dim them down a little with a resistor
ViewImage.aspx
ViewImage.aspx
wow those look huge!! lol do you happen to have a night time pic?
I dont have any pictures on me right now. Might be able to throw some up when I get home this weekend. Think I have some there. I'm sure you know already, but LEDs are always going to be brighter/better. I just went the cheap route. What kind of headlights are you running?
This is my corners with the lights I showed you above from ebay
P1070619.jpg~original
UGLY right?
These are with them with the headlights.
P1070617.jpg~original
I'd really like to get some that match my headlights which are Silverstars. bright white.
Ya I actually did the exact same thing you did orginally. Went with the blue tint bulbs and it looked goofy. Although the ones I finally found burn white instead of blue. I'll have to get you some pics this weekend.
yeah please any night time pics would be great!
2 V-LEDS WHITE 194 13 LED LIGHT BULBS 158 168 2825
i used these bulbs but i went with amber side markers. look pretty freakin good. id stay away from the other led's you picked out. they wont put out enough light in the entire housing
oo those look really good. I can't believe I didn't notice those on the site lol. Do you happen to have a night time pic? Because I think I might wanna get those lol. As you can see from the above pics the ones I got were horrible >_<
like i said mine are amber, but ill take a pic for you just in case :)
Edit:
here are the pics, firs is just the lights, second is with my piaa extreme white bulbs on low
IMG_1152.jpg~original
IMG_1153.jpg~original
obviously the amber doesnt get dimmer, its just my camera adjusting the lighting, but the look great together, plus i have the clear housing, and they are totally clear when off
Edit:
yeah those look pretty good but I'm pretty sure I'm going to get these
For the corners and a set for my license plate
plus these bulbs are $5 cheaper than the ones you picked out, but i would get those others for the front. and depending on if you want that slight bluish tint or not will dictate if you should get the 5k or 6k
