Broken mounting tabs on condensor
texadelphia
I had the grill off my rig and noticed that the lower mounting tabs on the condenser are cracked so the condenser is just hanging from the top 2 mounts. Probably happened in a front end collision before I owned it. Anyone ever repaired these? I was thinking about seeing if I could hire a welder to fix them but I think it might be aluminum. Also considering just JB Welding them and seeing if they hold. Thoughts?
May be get some radiator universal brackets and modify them to support the bottom.or some flat stock shaped in a vise.
You happen to have a photo of this Condenser tabs your trying to repair?
Sent from my SM-A505U using Tapatalk
seltzernator
