Highly confident that I have a blown head gasket and maybe cracked head. What's next?
4flyer
Member
Background:
I own a 2001 Toyota 4Runner with ~284k miles. I’ve put 110k of those miles on it myself, though it’s no longer my daily driver. It’s been an exceptional rig, and I’ve made it “mine” with extensive mods and maintenance. I’ve kept up with regular care—Mobil 1 synthetic oil changes every 5k miles since at least 2008, and in my ownership, the engine has never overheated. I monitor engine and transmission temps closely with a ScanGauge II. The truck is in solid shape overall, but I now suspect a blown head gasket or cracked head.
Symptoms:
A few months ago, I noticed extra exhaust smoke on cold starts, which cleared up once warm—I chalked it up to condensation. Over time, a slight misfire appeared at startup, later triggering a P0300 (random misfire) and then a P0303 (cylinder 3 misfire). I also noticed minor coolant loss, which I initially blamed on a loose top radiator hose. Suspicions grew, but since I wasn’t driving it much, I delayed digging in. Recently, I committed to a proper diagnosis. No massive smoke clouds or overheating yet.
Preliminary Diagnosis:
Two weeks ago, I ran a compression test using a loaner tester from O’Reilly’s—my first time doing one. Engine was cold. Results:
• Cylinder 1: 210 PSI
• Cylinder 2: 195 PSI
• Cylinder 3: 180 PSI <---
• Cylinder 4: 210 PSI
• Cylinder 5: 208 PSI
• Cylinder 6: 210 PSI
Cylinder 3 was noticeably lower. A wet test on #3 jumped to 250 PSI (likely too much oil added). The readings seemed high overall, and I didn’t trust the tester, but the delta pointed to an issue on #3, matching the P0303 misfire.
Secondary Diagnosis:
Last weekend, I tested again with a different loaner tester from AutoZone, this time on a warm engine. Results:
• Cylinder 1: 192 PSI
• Cylinder 2: 186 PSI
• Cylinder 3: 167 PSI <---
• Cylinder 4: 192 PSI
• Cylinder 5: 182 PSI
• Cylinder 6: 180 PSI
These felt more realistic for a 5VZ-FE with 284k miles. Still, #3 was below the factory service manual minimum of 174 PSI and exceeded the max allowable delta (15 PSI). Next, I did a leak-down test on #3 with a friend:
• Initial Pressure: 100 PSI
• Ending Pressure: 60 PSI
• Leakage: ~75%
We traced the air—no leaks to the exhaust, intake, or oil system. But when we opened the radiator cap, coolant erupted. Confirmation. Later, with the engine cold, I found a small coolant puddle in #3 via borescope. Other cylinders had typical carbon buildup; #3 was clean—steam-cleaned by coolant, I assume. No coolant in the oil, though.
So, #3 strongly suggests a blown head gasket or cracked head, right? What’s next?
Next Steps:
Assuming my diagnosis holds, I’ve got decisions to make. I want to keep the 4Runner. It’s not my daily anymore, and my plan is to restore it—fix mechanical issues, repaint it, even install new Katzkin leather seats I’ve got sitting ready. Over the last 50k miles, I’ve upgraded CV axles (CVJ), added OME springs and Bilstein shocks, mounted BFG KO2s, and built a dual battery setup, power distribution system, 120V inverter, molle panels, drawer system/sleeping platform, plus ham and CB radios. Put a good deal of work into the rig.
Options:
1. Engine Swap (JDM):
-Nope. I lack the space and gear for a swap, and I’d need a pro. Plus, I don’t trust an old engine with unknown history.
2. Engine Swap (Rebuilt):
-Tempting but pricey—$4,500+ for a Yota1 rebuild. Overkill for a non-daily.
3. New Head Gaskets/Heads:
-Tear down the engine over several weekends, replace head gaskets, and have the heads resurfaced by a pro. If cracked (likely), buy new heads and reassemble.
-Pros: Cheapest fix. Perfect time for water pump, timing belt, hoses, leaky valve covers, maybe a valve adjustment. Basically a whole engine refresh.
-Cons: Super labor-intensive, and surprises could lurk.
4. Sell It:
-Cut losses and regret it into my 50s (I’m not even 30). Not happening.
I’m leaning hard toward Option 3. It’s a chance to learn serious engine work, and with no rush to drive it, I can take my time. It’d refresh the engine and keep her alive. I only plan on doing 5k miles a year from this time out. If I go this route, what else should I tackle while it’s apart? Anything I’m missing?
A few weeks ago I watched a video by " The Car Care Nut" who is a Toyota technician and makes many youtube videos on all types of Toyota maint. & repair issues.
This particular video was on head gaskets. It was top notch and provided the kind of info that will help you.
This head gasket video should not be hard to locate as he has a strong following.
The Car Care Nut isn't going to show this guy how to pull the heads on his 5VZ-FE engine. So many people love that guy, but when it comes to showing the actual detail on how to do a very involved job, his videos come up WAYYY short. If you want general Toyota knowledge, sure, watch his videos. If you actually want to know how to fix something, you go to a channel like mine.
OP, I have a 7-Part Series showing how to do EVERY step of replacing heads on your engine. The Car Care Nut doesn't. I'll let you choose which channel to watch.
One more thing, I guarantee your head is cracked. The #3 cylinder is notorious for cracking between the intake and exhaust valves.
Yup. They sure are and he is a Toyota master technician too. Lots of other people out there doing videos as well in a pile of channels along with Tims. Tim does good videos geared for the beginner DIY and are detailed. :-) So you can watch a lot of them to get a good feel of what it takes to pull off the 5VZ-FE heads.
I was in the same position as you a couple years ago and did the same 3rd option you're describing. Using Tim's videos I got the heads off and sent them to Yota1 to be checked out (both ended up being cracked so they put my internal parts into new head casings).
I got them back rebuilt and that would've been the end of it but I luckily decided to check the block surface with a straight edge and feeler gauges. Most areas around the block had acceptable warpage but to my dismay some areas (around cylinder 3 I think) was way out of spec and really warped. So that sucked, but I gave everything to Yota1 and they treated it like a whole engine rebuild and did a great job. I figured better not put nice new heads on a warped block cause the gasket might fail prematurely. So the block might be worth checking out too. The previous owners to me treated this thing badly and had green coolant in it so you might be totally fine
Been there.
In my case - did the head gasket and then it turned out to be a hairline crack in the head..
Please don't make the same mistake I did..
I would get the head inspected. If it's good, get it machined and have new stem seals put in. Use the Toyota valve grind kit for your year of 5VZFE. Follow Timmy's videos too. He's so awesome that I wrote him into my ballot back in November.
I went through this two years ago, cylinder #3 showed minor cracks between valves, ended up purchasing new head castings and had them rebuilt with the factory valves and camshafts, of course the list goes on with what else you replace while you’re in there, but worth it IMO
Thanks, Tim. I have watched your videos and they are an absolute treasure. I will going into this as a head replacement as well :)
Right on. How long did the job take you? I need to make a list of what else to do. I have a bunch of cracked rubber!
preamble " Tim , your videos ROCK - thank you! I'm an old guy ok with vontage muscle, this lil 99 i am rebuilding ( maybe fooligly) is kicking my ass a bit...
The new engine mount seem to be holding the block at an angle i cant seem to grab with the trans! Arrgh! anyway.....
4FLyer sorry. im an old Vet that got in over my head on this one; its MUCH more difficult to R&R engine trans than old muscle.
Starts off when son#1 reports "steam" coming out the exhaust. clearly a head gasket, no need to check further. I REALLY liked driving the rig i buy it off the kid and we get it back to my place. i faced the same dilemma as you @ 280k.
I knew the lower end sealing was a bit weak as the engine got oil dirty QUICK, and i could feel a freckle of blow by thru the oil fll cap PRIOR to driving it back from Utah. A new BOSCH ignition and new NGK dual straps really LITE 'ER UP upon our return. Yet months later, she became a "stanley steamer".
Reman heads are over a grand a side. I once did a head on a MBz diesel only to exacerbate the blowby thru the rings ( 23:1 compression) , so I WOULD NOT put new heads on an engine with near 300K, with blowby. Even low compression like these. Only if the lower end checks out really well. I'd still bolt on a new oil pump and hyd chain tensioner if the 5VZ has one.
I opted for a reman from Remanufactured Engines & Transmissions | Gearhead Engines , which being an old man i could swing the $3500 or so, but being an old man, near 2 yrs into the warranty i have yet FIRED IT! ( almost!) and i cant benchpress a transmission like the old days.
big project. LOTS of wiring. again i am used to simple vintage iron. BUTT...new heads on on iffy shortblock isn't a good move imho.
So again, depending on the condition of the lower end, you're in over 2Gs just for heads. Even if the lower end checks out, new oil pump? cam wear? Check lash and reshim if neccessary, etc,
I almost wish i didn't go all the way as i ran into some frame issues ( repaired now with Safe-T-Caps, but not worthy of a full on resto) which made me wish a had pulled the heads FIRST to assess the damage. And then maybe pulling the engine, putting it on a stand and doing a "roadworthy rescue" rebuild on it my self. Ball hone that thing! New rings, bearings, oil pump etc.
Nonetheless, heads are so spendy, and its so much work anyway ( or spendy as labor), that it doesn't make sense to go half way.
I HOPE to report that the henco en mexico 5VZ from gearhead kicks ass. I will be very fastidious to ensure it runs in well and was in sealing on the pan, the internal coolant pipe, etc. Again, this being my planned retirement vehicle, i had a local shop freshen up the A340 trans as well. The T case looks mint.
BTW, pulling the heads would make pulling the engine a bit easier, so maybe so that route first? You'll still have to back the trans off to lift the engine near straight up as per FSM.
( after all this time spent, the other day i almost said " I SHOULD'VE LS'D IT! " ! ) :D
Deka
