Broken Plastic Caps
Bretski1
So I just installed my Yakima roof rack. When I was removing the factory cross bars I had to unscrew a star bolt to remove the wedge shaped caps at either end of the rail. When I tried to pull them out the tab that the star bolt went through broke off. I want to put the caps back in but I'm nervous about them falling out. Is there a less permanent option than gluing them in? I can take pics but it pretty straight forward. Thanks guys.
I did the same thing you did for the exact same reason. I was putting on my Yakima pads and broke one of the tabs attempting to get it back on. I tried glue but it didn't hold and broke again when I tried to put it on. There is a good chance it is going to fall off without the clip to secure it but I would suggest leaving it on in the meantime. Water can and will enter that little spot of the roof without it. Who cares if you lose it if you need a new one anyways. I don't suggest gluing it to the roof rails, if you ever need to get the cap off you're SOL.
Suck it up, go to the dealership and get some new ones. When I put them one the second time I wedged a screw driver covered in a shop rag under the roof rails. Be very careful to not scratch your paint or wedge it to far under as to break anything else. I just barely lifted the roof rail and it the end cap just slid right on. Super easy! Thus avoiding another break.
Just brought them into my house and I'm trying to glue the tab back on. Surprisingly, it's holding. I'll probably try to reinforce them with some epoxy or something, but all it's got to do is hold it from sliding out.
