Bug guard screws..?
trd_4runnin
Well I picked up a free AVS bug guard for my 4Runner but it didn't come with any screws. I am curious if anyone knows, or has a way of knowing what size screw I need to buy so that I don't have to use the ol' trial and error method.
Even better would be if someone broke their bug guard or took it off and had some screws they could send my way. I'd be willing to paypal someone a couple bucks for that!
Thanks.
Mine did not come with screws .... it came with plastic push pins that filled the holes when lined up under the hood. I was thinking it was a poor desing but I have never had a problem.
Mine came with screws and plastic push-in inserts that popped into the hood itself. After the insert was installed you buzzed the screw into it. Dont wast your time with these. Run to your local hardware store, buy some threaded rubber screw gommets, stainless screws, and washers. you can press these grommets into the holes in the hood and then thread your screws through. It may take some persuasion to get the grommets into the hood (i used a pair of needle nose pliers), but once they're in you wont have to worry about them coming out. Works 100x better than what comes in the kit and you dont have to worry about them loosening up.
