Help.
I need some advice about what might cause a quick bump. The entire truck will shake and the engine will quickly rock. I'm not sure if it's trans related or engine related. It happens at full operating temp, in gear when sitting at long stop lights. There doesn't seem to be any pattern as to when it will happen.
The engine is completely tuned up and then some. Cleaned MAF & ICV, new plugs, wires, fuel filter, and etc. I also checked the ignition coils. The engine runs smooth, RPMs are steady except for this random bump. Should I be looking for something like blown head gaskets, bad injector, bad trans....?
