Bumper fog light replacement/add in options
mattleegee
I have a sr5 and without fog lights, they slipped blanks in where the light would go on a optioned 3rd gen bumper, one of my "blanks" is missing and wanted to add lights in
My options
OEM on ebay is about $50-$90 each side then make my own switch or $xx for that also
(havent checked junkyards seems they would be about the same)
Then aftermarket:
And reviews on these???
Toyota 4Runner Fog Lights 4 Runner Driving Lamps Lamp A | eBay
Or i could just put a blank in (cheap option)
Any aftermarket ones people had success with? ideas?
i seen that set but the ebay auction is actually only for the lights
no hardware, switch, wires
ebay seller wants $165 which i can get OEM PnP at that cost, unless i didnt read the auction correctly
Your SR5 is already wired into the steering column, so you don't need a harness, additional wiring, or switch if you are going to do the new turn signal stalk. For hardware, it comes with the mounting brackets, and you'll use bolts already on your bumper to attach. The relay, which goes in your fuse panel under the hood, is maybe $10 at a parts store or dealer. His kit included these things when I bought but he has since scaled back a little. Still a good seller.
I'm going to be getting a new bumper soon and won't need my OEM fogs. Ill sell them to you if interested. No wiring or stalk though.
the dealer light stalk w/fog switch was $80.00 your trk is already wired for fogs so if you get GSPRunner's fogs then you'll be all factory....after market may be less expensive, but going factory (since they have done most of the work for you) is better, only thing is the fogs don't stay on when you have the high beams on...that's where/why I added extra Hellas to my rig.....good luck on your choice....
I see this is a really old thread, but if you just buy the stock, the lights, and the relay, it's all plug and play.
Additionally, does anyone know how to get a new lens cover? I had one take a rock and break and I can't find just the lens cover. Seems like I have to buy a whole new fog light.
In the same boat, cracked lens and hard to find in the salvage yard. Will likely go with aftermarket LEDs anyway that are amber :)
Runvod
