burning smell while descending under engine load
masphx
So I have noticed this three times over the last year. Happens when descending with some speed under engine load. 1st 2nd or 3rd gear anywhere from 5-30 mph while letting the engine control my speed rather then the brakes. Engine will climb to 2000-3000 RPM when I get this burning smell. I need to do some more testing but the rear window was down at-least this last time. Also the last time because of the downward angle the gas tank showed half full while in reality it was 3/4+ full.
What could this be? I checked around after smelling it and did not see anything out of the norm.
Planning on a five day off road trip into the San Juan Mountains in a month so want to make sure the rig is in top shape.
Thanks,
Mason
my foot was not on the clutch pedal,
Exactly. The 5 speed clutch is not a viscous coupling like an automatic transmission has. There's supposed to be a one to one transmission of power when you don't have the clutch engaged, so if your RPMs are higher than normal for a given speed and transmission gear, then the clutch has to be slipping.
Jhunt
