Bushings & Parts Retailer
psea17
Member
RE: 98 4RUNNER SR5 V6 MANUAL
Hey All,
Thought I'd pass along a little tip. I usually order my parts through Camelback Toyota but I got better pricing for this bushing project from McGeorge Toyota (VA) Certified Toyota Dealership Richmond - Toyota Cars For Sale
Here are the parts I ordered (or didn't order in the case of one item noted below for obvious reason): (ITEM PN QTY PRICE) Apologize for formatting.
Front Upper Control Arm Bushings (COTTER PINS NOT INCL) OEM PN 48632-35080 4 $28.09
Cotter Pins for UCA OEM PN 95381-03225 2 $0.89
Inner Tie Rods OEM PN 45503-39075 2 $143.00
Outter Tie Rods (PASS SIDE) (COTTER PINS INCL) OEM PN 45046-39335 1 $50.76
Outter Tie Rods (DRIVER SIDE) (COTTER PINS INCL) OEM PN 45047-39215 1 $50.76
Steering Rack Boots OEM PN 45535-35030 2 $17.85
Inner Steering Rack Boot Clamps OEM PN 90460-62006 2 $5.64
Upper Ball Joint OEM PN 43310-39016 incl boot+ 2 $38.92
Upper Balljoint Reboot Kit (NOT NEEDED; incl in UBJ purchase) OEM PN 43324-39015
Lower Ball Joint (Driver side) (COTTER PINS INCL) OEM PN 43330-39585 1 $99.20
Lower Ball Joint (Pass side) (COTTER PINS INCL) OEM PN 43340-39465 1 $99.20
LBJ Bolts OEM PN 90080-10066 8 $1.22
The remainder of the parts I ordered were all non-oem and ordered via Amazon:
Front Sway Bar Bushings & Endlink Bushings Energy Suspension PN 8.5141G 26mm 1 $20.33
Rack & Pinion Bushings Energy Suspension PN 8.10103G 1 $26.35
Rear Sway Bar Bushings & Endlink Bushings Energy Suspension PN 8.5142G 19mm 1 $20.57
Front Lower Control Arm Bushings Whiteline PN W53377A 1 $64.89
Rear Lower Control Arm Bushing Whiteline PN W63378 1 $65.02
Rear Upper Control Arm Bushing Whiteline PN W63379 1 $74.33
Hope it helps someone!
