buying a 95 4Runner
Ripper
I am looking at buying a 95 4Runner, fully loaded,126K miles. The only thing wrong is the passengers back window has a bad motor. Does anyone have a round about estimate on how much this will cost to replace? What are some mods that can be done to boost HP in the motor? thanks
if you buy the motor/regulator from a salvage yard, you should expect to pay about $75 for it. your avarage shade tree mechanic can swap it out in about 1.5 - 2 hours. its quite easy. im not sure what the labor manual gives as a labor time for a garage, but a decent mechanic will have that done in less than an hour. figure $50- $100 for labor if you have a shop do it.
or, do it yourself. once you have the door panel off, theres 2 bolts that hold the regulator to the glass, and about 6 bolts that hold the regulator to the door. an electrical plug, and thats it. easy.
